Old April 6th 2008, 18:23
V73W's Avatar
V73W V73W is offline
Finding hubs
I know on your website that it says to use 944S hubs on all the 944 turbo to SB/BJ kits, is there any N/A 944 hubs that will work with the turbo calipers and rotors on a SB? My problem is finding turbo or S hubs or at a decent price. Not a whole lot of 944T parts cars in south Mississippi and ebay's a joke when it comes to price.
Old April 6th 2008, 21:39
flat flat is offline
The late-model (87-89) 944NA and 944T hubs are basically the same, just the retaining screw (the littel M6 that holds the disk in place while you position the wheel) is in a different spot. Once the wheel is on the disk is firmly sandwiched in place, so it doesn't make much difference.
Else this can be an option: (sorry, about the plug)
http://www.thesamba.com/vw/classifie....php?id=577630
http://www.thesamba.com/vw/classifie....php?id=578538
Worst case scenario I can track down hubs around here, about $C170ish a pair depending on the season.
www.vdubengineering.com
