Old April 15th 2008, 10:19
Items for sale
I have the following items for sale, email for pictures.
1. Resurfaced porsche 914 215mm flywheel and matching stock pressure plate. Balanced as a pair, will hold 180 ft.lbs with stock clutch disc. $C160.
2. Near new (200 kms) 215mm porsche 914 6 spring clutch. $C80.
3. 228mm bus clutch nearly new (100km). $C80.
4. Remote oil cooler thermostat, -8 AN male fittings (2) + 1/2" hose bibs (2). Opens at 170F . $C60. SOLD
5. New T1 CV boots with flange, black X 4. $C20.
6. Porsche 928 S4 front calipers (2) with pads, great shape painted red. Use these with a 304mm x 32mm rotor. 2 X 44mm pistons + 2 X 36mm pistons. $C400.
7. Porsche 993T front rotors (L + R) used. 322mm x 32mm, thickness = 30.8mm. $C150.
8. EMPI forged dropped BJ disc spindles (L + R) NEW. $C160. SOLD
9. 1 set of Cima/Mahle 94mm pistons and cylinders. B pistons, NEW in box, comes with C clips. $C160.
10. T4 66mm crank with matching rods & rod bearings - polished and balanced, all is within spec, magnafluxed and checked for cracks - all good. Rod bearings look almost new. $C120.
11. T4 71mm crank with matching rods - this is the 71mm crank in my current 2.0 turbo motor, polished and balanced, magnafluxed - no cracks, rods have ARP bolts. $C200.
12. T4 94mm cylinders, Original German - These measure slightly oversize for a 94mm piston, but would be fine to bore to 95mm or 96mm. No broken fins. Used in my 2.0 T motor, checked for cracks - passed. $C150.
13. Web 73 cam for a T4, used for 1 summer with ceramic lifters. The only wear visible is slightly through the spray on dry moly (factory coating). You can feel or measure NO WEAR. This is for the cam only, no gear or lifters $C120. PENDING
14. Raby SLR'd lifters, new in the box. Bought from the T4 store in late 2006, would go well with the cam above. $C120. PENDING
15. Rayjay Turbo ... spins freely. $C40.
16. Porsche 1" wide wheel spacers with studs. 2 spacers total. $C120.
These items are available on other forums as well.
Old April 15th 2008, 18:42
petevw's Avatar
petevw petevw is offline
Sandeep,
I'll take:
interested in:
When were these purchased?
14. Rayjay Turbo ... spins freely. $C40
Is that the one you got from me?
'72 super
'65 bus
'52 split
Old April 15th 2008, 19:11
Thanks Pete.
The Cima Mahle set was purchased almost 1 year ago for my turbo engine, I was going to use the 94b's with my T4 rods rebushed for 22mm pins, but the machine shop could not do it in the time period I needed them.
So they stayed in the box ... I checked them yesterday and they still have the factory machining oil in the bores. These are brand new, never cleaned or opened from the original box. They come with the factory rings already installed and a grey coating of some sort on the piston skirts.
Yes the turbo is the one I got from you.
Old April 15th 2008, 21:22
I will take the Web 73 and ceramic lifters.
Are the lifters Schubecks?
Old April 15th 2008, 21:37
Sorry ... the ceramics are not part of the deal Do you still want the cam itself ?
Old April 16th 2008, 04:01
Sorry. I will pass. Just thought you were going to let the lifters get away. If they were going to get away, I was going to do my best to catch them.
Old April 16th 2008, 06:37
petevw's Avatar
Dave, I saw that from far and had a good chuckle. If Sandeep would have said yes, i'd be knocking on his door this morning.
'72 super
'65 bus
'52 split
Old April 16th 2008, 08:48
Items for sale edited to clarify the cam listing. I do have a set of Raby SLR'd lifters bought from the T4 store in late 2006 to go with this cam.
Lanner has the spindles. Thanks Lanner.
Old April 16th 2008, 09:17
Mark the canuck Mark the canuck is offline
I was just offered $700 for my set of ceramic's...well truth is I have 2 sets....
I said NO.
74 914-6, six conversion in progress. Major progress, twin plug macining done and all the parts coming together for a for a hot street 3.0.
'67 kombi, 2007cc, Summer daily driver.
'67 bug, painted and waiting for assembly, Empi GTV project, 102mm Nickies, 78mm crank, SDS FI, 2.6L T4 monster in the works. Now 98% done, just need to work on the the motorcycle ITB intake.
Old April 16th 2008, 15:21
petevw's Avatar
^^ Mark where have you been hiding?
'72 super
'65 bus
'52 split
Old April 16th 2008, 19:27
Added 1" wide Porsche wheel spacers with lugs.
Old April 16th 2008, 21:56
petevw's Avatar
How many spacers? Full set of 4? 20 lugs?
'72 super
'65 bus
'52 split
Old April 17th 2008, 07:05
2 spacers with studs only, edited first post.
Old April 19th 2008, 08:46
Cam and lifters ... sale pending
Old July 7th 2008, 22:57
CLKWRK's Avatar
CLKWRK CLKWRK is offline
hey Sandeep,
Whats the story on that rayjay turbo?
im looking for a smaller turbo, email me if you still have it
iambryan@hotmail.com
cheers, Bryan
GL ghia restoration:
