Old April 17th 2008, 00:50
DORIGTT's Avatar
DORIGTT DORIGTT is offline
What rear brake parts to use?
Other than whats here in this picture, what else (other than rotor, caliper) do I need / can use from my early 944T aluminum arms to mount Porsche rear brakes to my steel Ghia trailing arms?
Old April 17th 2008, 21:02
flat flat is offline
The pic shows some relatively rare parts, they are from a 924T. The swingaxles guys love them.
The only other parts that are interchangeable between steel arms and alum arms are the shoes with all the springs/hardware.
You then need the early hubs. I may have a set around, I'll check if you are interested...
www.vdubengineering.com
Old April 18th 2008, 00:47
DORIGTT's Avatar
The early hubs will come in quite handy then.
I take it I can't use the hubs from my 86 aluminum arms eh?
And other than that, they're 'ready' to bolt on and be used on my IRS arms correct?
