Old May 1st 2008, 01:21
DORIGTT's Avatar
DORIGTT DORIGTT is offline
What makes the 944 rear arms more adjustable
What is it that make the 944 rear arms more desirable than the VW arms?
Old May 1st 2008, 19:45
Mr Big Mr Big is offline
I havent seen the ali ones close up, but the only difference I could find on the steel ones was the facility to run a rear anti-roll bar.
1969 German Looker in progress:
1776 turbo EFI motor (eventually!)
Built IRS Box
944 Turbo Brembos (Fr)
964 C2 Brembos (Rr)
Old May 1st 2008, 22:39
The 944 spring plates for steel & alloy arms are adjustable for height, the toe & camber are more easily adjusted with both the alloy & steel arms.
You gain extra distance between the wheel bolt faces which can aid you when fitting Porsche off set wheels.
Of course you gain very good rear disc brakes.
Old May 6th 2008, 09:17
Bullyboy Bullyboy is offline
Old May 6th 2008, 11:27
DORIGTT's Avatar
Can the 944 adjustable springplates be used with the STD IRS arms?
Old May 6th 2008, 13:17
Nope,
Bolt pattern is way different
Old May 7th 2008, 01:26
The ones from the steel 944 arms can be used with late bug arms (single spring plate type) OK. The 944 v bug arms, the 944 arm has an extra hole drilled in it for adjustment.
