Spring Plate removal
So, it's a bit of a newbie question, but what is the best/safetest way to take off my spring plates? I figured it was something like:
1. with enough load on the wheels to keep teh spring plates off of the torsion bar tube unbolt the retaining cover. 2. use a pry bar to nudge them past the end of the torsion bar housing 3. Raise the car to completely unload the torsion bar 4. Pry the spring plate loose. Like I said, that was my first thought, but I'm sure there is a lot safer/simpler way of doing it. Thanks for everyones help. |
Use a jack on the spring plate, or a proper compression tool, with the car up on stands
This needs to become a sticky for repitition sake...
http://www.germanlook.com/Forums/showthread.php?t=5074 Jason
If I could just get paid for my sleepless nights.... 1960 VW Bug UBRDUB Walkaround 1st Drag Run Dyno Run Oval Ragster-'57 Rag/'04 Boxster S |
This would make a great tech article if it had some pictures. I am more of a visual person my self.
I was thinking that. I figured when I do the swap to 951 trailing arms I would write one for that. Spring plate removal would be part of it of course.
Sorry, I've been without springplates for years now, but if I find myself doing it again I'll snap some shots!!!
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
