Old July 12th 2008, 18:01
ernyb ernyb is offline
crx springs
When using the Honda CRX rear springs on the front of my 1302, do I get any lowering from stock height if I use my stock struts or do I need to use adjustable struts? Thanks for any help, Eric.
Old July 12th 2008, 21:51
petevw's Avatar
petevw petevw is offline
You'll need adjustable struts. The CRX springs alone will not drop your ride height.
'72 super
'65 bus
'52 split
Old July 12th 2008, 22:20
crx springs
Pete, thanks for the quick reply. I'll go with the adjustable struts then. Eric.
Old July 14th 2008, 00:25
crx springs
Pete, I have one more question if you would be so kind. When you used the crx springs on your front struts I assume you lowered your car. What shock insert did you use to make the whole assembly work properly. Thanks, Eric.
