Old September 7th 2008, 19:53
vwbloodline's Avatar
vwbloodline vwbloodline is offline
944 NA calipers
I have searched and it always is that someone is putting na porsche calipers on VW drum spindles. But I must know is it easier to make brackets and mount na calipers to vw drum spindles or disc spindles. Thanks I am getting ready to buy drop spindles and didn't want to get the wrong ones.
If you understand, you have lost all sense of understanding...
Old September 8th 2008, 20:18
I searched with better terms and found out that it is a lot easier to mount Porsche brakes on drum spindles. Disc spindles create a problem where the caliper must be cut, drilled, and taped. Sorry for creating the thread.
Old September 14th 2008, 18:11
Sunroof53's Avatar
Sunroof53 Sunroof53 is offline
Dropped spindles will not work with na calipers .The steering arm fouls caliper
The wisest mind has something yet to learn
Old September 15th 2008, 07:44
What if I move the caliper to the opposing side?
Old September 15th 2008, 20:17
flat flat is offline
Then the caliper hits the trailing arms on turn. I've put the NA calipers on dropped spindles, but it does require alot of machining of the spindle for caliper clearance. I prefer to use the socal welded spindles for that application. I've done a handful, and am no longer doing the conversions due to the amount of work required. It's easier to do a 944T setup on a dropped spindle.
www.vdubengineering.com
Old September 22nd 2008, 08:16
With the turbo caliper what is the best choice of spindle for ease of mounting modification? Disc or drum?
