Old October 13th 2008, 15:52
Turbo Haraune2's Avatar
Turbo Haraune2 Turbo Haraune2 is offline
Camber plates
I want to fit camber plates to my super, and wonder if anyone have suggestions on wich plate that can easyest be modified to fit the super?
I have never seen or heard of camberplates that is direct bolt on to my car. Thats why i think it is easyest to get a ebay thing and modify it.
I dont want to take the easy cheap way of elongiating the original holes, because that is not safe, or pretty
Old October 13th 2008, 16:51
I still am hoping Lanner will start making these...Although I want them to set caster. Camber is easier to set with the Topline stuff downwards in the rection arms and if you have Golf struts with the lower bolt holes.
Old October 14th 2008, 08:11
Guys, check this out. http://www.demon-tweeks.co.uk/produc...09&tlgrp=MS002 The variability on the top mount should work for both of you. To use the camber plates or strut top mounts (in English) you will need to use 2 1/4" springs to allow enough space to relocate the top mount to give you the extra camber and/or caster and that will probably mean new strut legs with say adjustable plates. It all starts to get expensive and the wrong side of £1K
evilC
