Old October 15th 2008, 02:06
some bits and bobs
one set of 993 spec 17 inch cup 2's 7 and 9 et 55 and 70, tyres worn
-rare set though!!! £500
another set of cups, but 928gts spec, even rarer =similar to 968 mo30 -7.5 and 9, et 23 and 15 good tyres on these, but cheepies £500
pair of 275 by 40 17 inch tyres -dunlop 8000's £100 -realy good
set of 4 red 996 calipers 318 and 299 with the servo prop valve mc and pot - pads pins and clips/caliper bolts £500
pair of new 944 turbo rear discs £100
pair of new 996 front discs £110
pair of used 996 rear discs £30
pair of used 965 964 turbo discs-front skimmed £60
944 front spindles -early and late ones £25 a pair, are these the same as 916?
for sale, split scrren single cab truck all welding done, running on 944 turbo rear and 68 bay front -with cup 2's 255 tyreso n rear - bare metalled
no engine or box, a fine truck - fleetline needs plenty of stuff doing £4000
vw beetle -super 1303's' 1973 no mot, taxed till end of dec, just enough time for you to sort out a new channel on the drivers side, and the few other bits, comes with 5 70's wolfreace wheels - last owner since 75
£950
subaru 2 litre engine, a rjes bell housing, a t25 4 speed 091 dk gearbox
-was going in the splitty, £1000
all the stuf is in fulham london call 0774 858 2044, thanks
