Old November 14th 2008, 02:06
Veedub Veedub is offline
1776cc
m going 1776cc 73x88 by the way. Do I run 94mm bore heads, since the 88's matche the bore thickness?
Just trying to get and idea what it will run like.Maybe a hp, torque guess?
CB's Eagle Racing (Performance Level 5)
Reason, short duration, higher lifts, power to come out the turns ( i love to go round the corners, yeah...)precise throttle response (dirt an sand dont matter...) and topend to scream down the straights. Its what I want :P
Adv Dur. 286, Dur. @ .050" 240, lift @ cam .386"
Straight cut cam gears (for the noise)
1.25:1 racer rocker arm kit
Mini Wedge Ports 42x37.5 94mm bore
SINGLE 44IDF Weber tall ram kit
88mm machine in pistons
73mm, 2" chevy journals, ballanced 8 dowel, and heat treated
forged chromoly 12.5lb flywheel
1 5/8" merged header w/ stinger
hideout muffler on the street
Gearing stock for now but with 23" tall tires in the rear.
What you guys think?
Thats what my motor project will be once my moms out the hospital and everythings back to normal.
