Old November 14th 2008, 11:20
bamberjim's Avatar
bamberjim bamberjim is offline
Turbo
I am just stating to collect some bits tohgether for an eventual turbo conversion and was wanting some advice for a type 4 2.0
I already have a T3 charger spec below
Features a 3" Inlet and 2" Outlet
Features Wet Float Bearings
1/8 NPT Oil Inlet
.50 A/R Compressor
.63 A/R Turbine
T3 Flant
5 Bolt Standard (.58) Down Pipe Flange
Turbine Wheel: Exducer: 2.2", Inducer: 2.58"
Compressor Wheel: Exducer: 3", Inducer: 2"
I was wondering what sort of single carb would be good to use with this )using porche shroud on the engine, also what inlet manifold and exhaust manifiold... are they all custom made? who make them etc
Any advice would be great
Cheers Jim
Old November 14th 2008, 17:40
aircooled4life aircooled4life is offline
go with fuel injection. either CB performance or Mega squirt (are cheapest and most simple).
and post your turbo dimensions in mm not inches.
Old November 15th 2008, 04:08
blitzvw's Avatar
blitzvw blitzvw is offline
EFI - why use old school carburettors?
Blitzem with Type 4 power
Old November 15th 2008, 14:11
bamberjim's Avatar
cost is a main factor, carbs seem to be alot cheaper than EFI, unless someone can correct me?
Old November 17th 2008, 10:26
Cos the carb will have to be a blow through that is a whole lot more difficult to set up especially as carb were originally designed to work on a partial vacuum. It will be a whole lot easier to set it up on an EFI than carb(s), give more power and save on dyno time.
evilC
Old November 17th 2008, 15:05
bamberjim's Avatar
How much is a budget efi system going to cost?
Old November 19th 2008, 09:03
How handy are you?
Its always a balance between your own capabilities and an already made system (anything other than megasquirt)...
You could do suck through, but that would require even more experience with sidedraft carbs imo. Best to go to someone who has something similar running and ask the details there.
In general EFI rocks but does cost some and even then you must do it all yourself. The rewards are high though. I made 270hp on a basically stock 2 liter type 4
But if all of the above is out of reach for you, you could probaly get more hp from a relatively simple increase in bore (103) and stay N/A. That could get you an easy 175 hp with the right heads and 44 IDF's.
However don't get the misinterpretation that just turboing it give you an easy 200+ hp. 200+ hp is never easy nor cheap. Just more easy to attain with turbo then N/A, but costs about the same... unless you are a reaaaaally good/experienced wrench and use all used parts. Using used parts and tuning it right is however even more difficult and/or time consuming
Old November 19th 2008, 10:31
blitzvw's Avatar
www.gotech.co.za - A nice alternative to MegaSquirt
Old November 19th 2008, 16:35
bamberjim's Avatar
Cheers for the answers, i think i,m going to put the Turbo away for a while and stick some 44's on and run it like that for next 12 months with reccision looming.
What sort of power will a 2l type 4 with Eurorace e grind cam, 44's with full flow exhaust and 6AL ignition make... rouch idea's.. my old stroker made 104bhp at the wheels and was hoping for something similar... may have to ge some headwork done?
Old November 19th 2008, 17:15
S/th similar at the wheels is surely possible, but then you need at least some head work. With really good head work/exhaust a 5-10 hp more is possible too
Old November 21st 2008, 18:05
bamberjim's Avatar
Lets hope so...., not sure if any headwork has been done to be honest, have ordered a LAP exhaust, got a mallory CDI 6al box and the 44;s to go on so will see how it feels... any experts on Jetting here need some basline figures to get started
the carbs currently have
f7 emulsion Tubes
135 mains
120 air correction jets
thinking this is all going to be very wrong...!
any suggestions would be great...
Thanks for all the input
Jim
Old November 22nd 2008, 07:02
New 44'ers come with the right baseline jetting already, so don't worry. IIRC its s/ th like 135/190 with 36 vents and 55 idles.
