Old November 29th 2008, 15:09
944 n/a hubs on 412 spindles..project
Since I wanted to use vented disks up front too, I am going to try to adapt 944 (n/a, early) front hubs so a type 1 bearing can be used for an inner bearing and a spacer bushing will be used for the outer (944) bearing as the 412 spindle is a litte smaller in diameter and not the same as a type 1 spindle. It does use the same type 1 bearings though
Here is the adapter ring on top of the still original 944 hub:
This is after the hub was shortenend by 6,5mm and the inner part openend up for a shrink fit with the adapter piece:
After heating the hub in the oven and putting the adapter ring in the freezer, it fell right in
Next job is to install the wheel bearings and try it out on a spare 412 spindle...
Old November 30th 2008, 11:25
Well, the 944 hub fits nicely, but could have used a little more room on the nose for the retaining screw/clamp and washer. I might had better shortenend it by about 10mm I think now, but its work this way as well
Tried the 944 caliper, but its too close for proper fitment:
(pity, as the bolt hole spacing of both calipers is exactly the same...)
This also leaves open some other disk and caliper options hehe..
To be continued.
Old November 30th 2008, 22:32
Wally...you got too much time on your hands. Great job though!
Old December 3rd 2008, 04:30
Chris Percival's Avatar
I did something very similar, but to fit 1303 hubs...
http://www.fastbug.net/node/219
Old December 4th 2008, 02:00
Hi Wally
Nice work. This is what I did to adapt Porsche callipers to my 1302.
