#946
I thought that he was after the part number for the bolts. Steve
#947
Hi Steve,
I looked in the same place as you, the 996 carrera catalogue but the optional LSD for the 996C is different from the "motorsport" LSD used in the GT3/GT2 and the bolts specified for each are different. Hopefully, the bolts will fit with the G50 Crown gear. It is difficult to see how they wouldn't. |
#948
Its a shame that Porsche don't have a "Lack & normal tellie" section like VW where you could look up bolt and other part numbers by description. Steve
#949
Picked up the correct bolts for exactly my differential and got a mail from Paul to use 120 lbs.ft and a drop of red Loctite.
There is a difference in length, but not exactly as much as the difference of the flanges. Anyway, it will do fine I think.
#950
Just reassembled everything and very happy I got the spacers and bearings pressed on again without any trouble. Ring gear was extremely nice and tight fit on the much later dated diff housing. The machining on these parts is amazing!
#951
After a lot of work pulling the engine forward far enough to get the thicker diff back in, I got the engine back in its place again. Filled tranny with new synthetic 75W90 Valvoline and reused the O-ring n the side cover (even though I still have a new one from the gasket set). If you turn one wheel, the other one turns in the same direction as it should with a LSD
It turns nice and smooth by hand.Got the engine running again and went for a test drive. No extra noises, all seems just fine and dandy. Did a deliberate lighting of the tires in second gear (cold and damp road) and that felt different somehow, more aggressive in a way, but not out of control. Car is still stupid fast and seemingly effortless at doing so. At home, tranny is still bone dry as before. All in all, this was relatively easy sailing, though I didn't know that up front.. Gotta love orginal parts
#952
Hi,
Nice job but before you go any further, are you sure about the oil you put into the tranny? Usually in a 911 with LSD (old ones), oil is something like 75w140 (not sure about the exact values but sure about the range). I can check if you need the exact values. Seb |
#953
Well done Wally! It will make a world of difference I´m sure!
#954
Yes, very sure: besides the fact that this is not an old tranny 911 type with porsches' own syncro system (which indeed needs a different oil), its actually counterproductive to use thicker oil or specially formulated LSD oil: The latter usual has friction modifiers, which reduce the effectiveness of the friction plates. In that sentence alone, you can see/read how weird this is... Those 'special' lsd gear oils were made because they reduce noise of the friction plates (in slow corners or in the parking lot), which is very liked by the typical Porsche owner who wants a comfortable a relatively quiet car. I just want performance
#955
Good luck with the diff!
I wouldn't go too crazy with the burnouts though. Replacing the clutch pack with "cup spec" (not the crappy road clutches) costs over £600 from Porsche. |
#956
![]() Both in performance as in duration
#957
![]() Bet you can't wait to get it on the track
#958
You got that right! I also changed my front springs to 'very stiff'...: I thought I had changed to 350 lbs springs in the past, so I now ordered some +50 lbs ones (400). Turned out they were still 300 lbs... (very nice ride quality, but for track could do with a bit harder), so the difference is a 'bit' more then anticipated LOL.
Also re-installed my self-adapted 'wing' for extra downforce. Indeed curieus what it will all do/mean on the track. |
#959
You will see a big difference in your lap times. The car must be amazing now.
VW 1303s 1975 (German Look) VW 1300 1964 (Rally Car) LAND ROVER DEFENDER 90 V8 BMW E30 318i CONVERTIBLE 1992 Italian Toys - GERMAN WAR MACHINES ![]() WRC is for boys - GROUP B WAS FOR MEN |
#960
Have fun on the track... Seb |
| Currently Active Users Viewing This Thread: 13 (0 members and 13 guests) | |
