Old November 9th 2003, 18:26
yetibone's Avatar
yetibone yetibone is offline
Does the engine turn over like it has even compression on all cylinders?. If so do what Cooter said.
Set the throttle stops first. Then hook up the linkage ans make sure both carbs open at EXACTLY the same time.
If you're using Hex-bar linkage, then because of the tortional flexibility of the aluminum Hex-bar, the left side carb will try to open first. That can be compensated for with adjustment of the little heim joints and turnbuckles at the ends of the Hex-bar arms.
Yetibone
P.S
Hey Yeller,
I went to Northwood HS!
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
