Holy yellow banana of all brakes!
T4 2666 1303s |
Hi,
I`m using disc brake spindles of a 72 ball joint axle, took 2 CSP discs (SEBRO) with Porsche 5 stud pattern and machined them down to the inside diameter of the GT3 discs and use them as hubs. Then machined the back of the discs(hubs) to fit Porsche press in wheel studs. It is pretty much a bolt on kit, the discs (GT3) have plenty of clearance. After that was just measuring up for the caliper brackets and getting them made. On the rear is the same stuff as most of you are already using, 944 hubs and backing plates, modified handbrake adjusters (thanks for the tip Sandeep) and new BMW brake shoes. My goal was to fit this brake with 17 in wheels even though they fit 19`s to the Porsches. It is very tight and there are only 2 mm clearance between the caliper and the rim, had to take the balance weights away there. The wheels were another problem as I already had a set of Boxter style 996 wheels (twisties) which did not spin as the caliper was sticking out of the hole. Would have needed a 30 mm spacer to clear it. The ones on it clear it nicely with a 10 mm spacer and don`t look to bad, so they stay. Discs are 330 mm on the rear and 350 up front, gonna try 944 master cylinder and brake proportioning valve for the rear. There will be a lot of testing. The tyres are 205/40 in the front to keep the original look, so testing different components to ensure driveability is necessary.
Andreas |
No worries, if you want to add the pics to the gallery go ahead Zen.
Cheers
Andreas |
WARNING the following your about to read is a bad joke, disregard:
Is that a banana in your pocket, or are you caliper to see me?
Oh that is bad...
Bummer, should have fitted red ones
Andreas |
Just wanted to inject a sad possibility here. Keep in mind if you were to hit an object at high speed, say a rock or a piece of lumber, or even a pothole, and the rim bent, it has to bend less than 2mm or your looking at harps or heat. Not to be the bearer of bad news, but I've seen those wheels bent more than 2mm, I'd just hate to have anyone injured or killed in the name of looking cool. Might I suggest stepping up to the next size wheel? That should introduce enough safety for this problem at least. It does make me drool though.
Ha Ha, I laughed
Coming Soon! 86mm X 90.5mm German Look Bad *** VW Hopefully Soon!! Back home in Port Orchard, and saving for the Bug |
[QUOTE=Typ Vier]Hi,
It is very tight and there are only 2 mm clearance between the caliper and the rim, had to take the balance weights away there.[QUOTE] I got half way through this sentence and my brain was already fixed on the sticky weight clearance. Although these wheels should be static balanced, did you have them 2 plane balanced? What was the end result of the balance issue? BTW, great work you've done there! |
The wheels have not been balanced since the clearance problem occured, have to talk to the guys at Frank Allen tyres here on what to do. They`ve got the latest equipment for tyre fitting and balancing and hope fully come up with a solution. The wheel design does`nt really give you many options with the spokes sitting so far outside. Could move the weights more to the outside from the original location but then I would need 10 mm wide balance weights to have 5 mm clearance from the outer edge to the caliper. Most weights are around 20 mm wide.
Later
Andreas Last edited by Typ Vier; November 27th 2004 at 23:10. |
Impressive looking project. Must've taken a lot of planning. Looks fantastic. (I guess you won't be making the 12-hour flight with it to drive the streets of Baltimore city, though.)
A trip to Baltimore......tempting
Just jump in a plane in about 1 year and we go for a drive along the Tasman sea
Andreas |
Once again, your brakes are awesome!
But do you have a picture of the backside of the disc and the hub mounted on the spindle? Care to join your meashurements on the caliper-bracket?
1963 Germanlooker projekt 1969 T-1 daily driver |
