Old February 28th 2005, 21:59
Diego74 Diego74 is offline
thanks a lot for the info that really helps. Im planning on getting discs for the rear and already installed them on the front. Now all i need to do is save up 2 grand for new wheels or find some used does anyone know what other porche wheels come with a 55mm offset. Ive read the topline article in the hot vws mag that 55mm was the only ofset to use and I was also wondering whats the largest diameter wheel can I use with out rubbing and still lower the front and rear Thanks
