#46
That chassis looks totally sick. It'll be a blast on the track when it's done.
And I'm taking notes. I'd like to do a super next time around if I can't find a good T3.
72 Standard- 1600 stocker..for now It's YELLOW Rolling on a daily basis. VKG |
#47
Thanks!
I've always thought that GL Type IIIs' are to GL Supers', what a Mercedes Benz E55 is to a Porsche 911. I've never owned a Type III, but I still think Supers are where it's at! :agree:
#48
I've always wanted a Squareback. Heck, I might even do a Bus. But surveying the aftermarket, I'll probably end up with a Super. T2's & T3's are just so much more expensive in every way. And down here, they're so hard to find in good shape. Plus I get envious reading all of the Super threads!
#49
GL T3's more like a BMW M3 vs Supers being like 911's.
#50
#51
They look great!I want a new cluster too.
#52
Couple of pictures of the Kerscher dash. Not done with it yet. Gotta get a 911 clock, and paint it, or gel-coat it.
#53
Sweet dash
90 in to te corner. |
#54
Same dash that I have, only I have to modify it even more..
Looks nice!!
B-Extreme B-Tuning..... Racebug is comming to get ya!!! |
#55
That dash looks great Joe!!!
73 Type 1 - 2270 Type IV 64 Type 34 - 1500 Type III |
#56
I started doing actual bodywork today. Made a patch piece out of a section I got from jhelgesen. I cut the rusted section out months ago to make it easier to remove the wiring harness. I left the fold on the underside of the drip rail intact, so the patch will be inside the fold. I haven't stitched it into place yet 'cause I have to make some patches for the inside, lower rear window corners.
The other side will be easier 'cause I don't have to cut the outer window corners, just the inside.
#57
Most 1303 supers are terible about rust in that area. I've seen a few that were a lot worse than that. The patch looks good to me.
Mike '04 R32 Tornado Red '02 New Beetle TDI - Daily driver '64 Ghia - Project!!-Subaru EJ20T, MS/EDIS, 993 brakes, 914 Tranny... Last edited by Mikey; September 12th 2005 at 13:11. |
#58
My '73 has foam that's kinda like 'Great Stuff'. It's not flexible.
#59
Yetibone, why didn't you removed or blasted the rusted (inner) piece at that corner?? (it looks rusty to me)Sorry I was reading too quicky
Keep up the good work. ... It's an place were almost every 1303 is damn rusty. (I had to cut out hole the corner (inner and outer piece) en welded in an doner to make it nice)
#60
I figured your car had much more extensive damage than mine as it looked like you had replaced the whole base of the pillar, not just sections of it like I'm doing.BTW, excellent bodywork Wiebrand. :agree:
