Old August 20th 2005, 23:55
onixbonilla's Avatar
onixbonilla onixbonilla is offline
911 alternator
Hi!
I have a 911 alternator with a 12 blade fan.Do not know the year of the car it came from, probably a late 993. Will like to know if someone had any experience with them, and or know how to wire them?
Onix :idea:
Old August 21st 2005, 17:16
I have not wired a 993 alt. If you can find a wiring diagram for the donor car you should be able to trace the conections. Remember that if the car you are intalling it in has a voltage regulator, you must remove and bridge it first(you can find diagrams for this on the net. Search for VW alternator coversion).
Old August 21st 2005, 21:34
Thanks for the reply!
My car already have the internal voltage regulator conversion done. The 911 alternator have in the back multiple conections but I think I know the important ones.
B+ for the battery
D+ for the dash light
W I think for the ground
Also had a terminal wich is marked only as +, not know where it conct it, but anyway I only have 3 cables for conection(above ones)
Any sugestions?
Onix :idea:
