The only thing I've ever seen with hard lines are those brass or aluminum block style... pick up a Street Rodder mag at the newstand, there are several companies listed that do nothing but brake hardware.
I'm in the process of upgrading a few things on the bus myself. Nothing as glamourus as your stuff, changing over to dual circuit M/C and adding a bias valve... are you planning to use the knob style or lever? Jeff-
No current VW projects 54 Chevy wagon LS2 AWD 56 Chevy Panel "Lost Cause" VKG Bastage child |
What sort of ends do those steel lines need anyway? I heard SS lines have to use some special pressed end or something. I havn't had any experience with brake system construction, just OEM type replacement. Jason
Educate me a little... bias bar means you have independent cylinder and resevoir for the front and rear and the bar limits pressure on one or the other?
Pressed end? Not sure about that either. They do have a specific flare (degree amount) on the ends but that's all I was aware of... It would be really cool looking if you could use braided everywhere but of course that's a big no-no and a wee bit pricey. ![]() Jeff-
you can buy a good flaring/bending tool for less than $100 from most places
Hopefully, if I select the right master cylinders, I won't need to get the proportioning valve, and just the balance bar will be enough to dial it in. "you can buy a good flaring/bending tool for less than $100 from most places" I've got a couple of benders already, but I don't have a flaring tool. I've also heard there are specific flares for specific situation ie the angles, so I'm going to have to do a little research before I can get it done. Jason
