Components (Continue)
Slide 15 Bug@5-Speed Kit Components
Bug@5-Speed also carries Inner Shift Forks for use when converting 914 tail and side shift gearboxes ![]() ![]() Slide 16 Bug@5-Speed Kit Components Bug@5-Speed also carries Modified 901 and 914 TOB Forks for use when converting 901, 914 tail and side shift gearboxes Modified forks are bent to provide better geometry These can be purchased on an exchange basis Lever is newly galvanized after the modification/adjustment*and equipped with a new guiding socket at the back.* ![]() ![]() Slide 17 Bug@5-Speed Kit Components Bug@5-Speed Gearbox Output Flanges ![]() ![]() Come in two sized: Stock Beetle diameter (78mm) 944/T2 diameter (86mm) Machined and Hardened Note: early 901 flanges have larger opening and must be specified
Alex Olaverri Sales Associate for Bug@5-Speed (US) Email: Bugat5speed@yahoo.com Tele: 973 204-5463 Last edited by Bug@5speed(US); July 17th 2008 at 21:22. |
Slide 19- Getting Started (Partial Disassembly)
![]() Drain oil via two plugs on the side of the gearbox (17mm Hex Drive) Lower plug is magnetized to capture filings It is a good idea to inspect this plug to have an initial idea of condition of internals Slide 20 Getting Started (Partial Disassembly) ![]() ![]() ![]() Removing Flanges Utilizing 1 inch square stock special tool is made to prevent flange from spinning Bolt on flanges are size 19mm and are referred to as diff expansion bolts Slide 21 Getting Started (Partial Disassembly) ![]() The differential side cover/plate is secured by 13mm sized nuts Removing of the side cover is necessary in order to flip the differential This is necessary on the 914 gearboxes due to the 914 boxes being set up for mid engine configuration Failing to due this will yield one fwd gear and 5 reverse gears Slide 22 Getting Started (Partial Disassembly) ![]() Side Cover removed exposing a poorly maintained gearbox This is not what you want to find With cover removed it becomes evident that in order to remove the diff, the pinion shaft and main shaft will have to be removed Slide 23 Getting Started (Partial Disassembly) ![]() ![]() ![]() Few more items that need to be removed to enable the intermediate plate, and gear stack to be pulled away from the case to access diff Unbolt 2 13mm nuts to removed side cover plate; freeing inner shift rod Removed reverse gear switch and pin
Getting Started (Partial Disassembly) (Continue)
Slide 24 Getting Started (Partial Disassembly)
![]() With the intermediate plate and gear stack out of the way you can now pull the differential from the box Now reinstall with differential Ring Gear facing the opposite way Reinstall all items in reverse Slide 25 Getting Started (Partial Disassembly) ![]() ![]() Nosecone is secured to intermediate plate via 13mm nuts. Once nuts are removed utilize a rubber mallet to remove nosecone Take caution when removing the nosecone, as the reverse gear assembly may fall out/off Slide 26 Getting Started (Partial Disassembly) ![]() ![]() With cover removed now is a good time to transfer reverse gear shaft onto your new nosecone Example shown of early 901 nose cone Utilize a small punch and remove small pin Remove reverse shaft and relocate onto Bugat5speed Nosecone Reinsert small pin to secure/lock reverse gear shaft Slide 27 Getting Started (Partial Disassembly) ![]() Reverse Gear shaft shown on the old nose cone ![]() Reverse Gear shaft and locking pin
Slide 28 Getting Started (Partial Disassembly)
![]() With Nose Cone removed, now is a good time to remove the speedometer drive gear Two approaches (1) Use a hacksaw and cut (Not best approach) or (2) Remove Expansion bolt (held in place with (80-87ft/lbs) and decouple drive gear (Better approach) Slide 29 Getting Started (Partial Disassembly) ![]() ![]() The Expansion bolt is size 32mm, and will require that you lock the gearbox down in order to utilize an impact drill to remove. There are many methods to locking the gearbox, one such method is to utilize an old clutch disk, using some one inch stock and a few bolts (See side picture) Slide 30 Getting Started (Partial Disassembly) ![]() Once expansion bolt is removed from, you will notice that the speedometer drive gear is secured via a small pin To separate remove lock pin Slide 31 Getting Started (Partial Disassembly) ![]() ![]() The Bug@5-Speed Nose Cone and Front Traverse are shown on the right. With the reverse gear shaft installed and locked in, you can attach nose cone to the intermediate plate and gearbox. Be sure to replace the factory gasket or utilize a liquid gasket to create a good tight seal Secure to gearbox with the self-locking nuts and washer Torque 13mm nuts to 18 ft/lbs (Per Porsche Manual
Slide 32 Getting Started (Partial Disassembly)
![]() ![]() The Front Traverse is secured to the nose cone via (4) hex bolts This is what the final nose cone and traverse should look like. Slide 33 Getting Started (Partial Disassembly) Bowden Tube/Clutch Cable Adapter Plate Install (914) ![]() The Adapter Plate is utilized to redirect and establish proper geometry for the clutch cable and Bowden tube Install is accomplished by placing adapter plate onto differential side cover via two 13mm nuts Shown is install on a 914 gearbox Slide 34 Getting Started (Partial Disassembly) Bowden Tube/Clutch Cable Adapter Plate Install (901) ![]() While the 901 early gearbox has an eyelet for the clutch cable, this is not the optimal setup. It is recommended to use the Bug@5-Speed Adapter Plate. The Plate is utilized to establish the proper geometry for the clutch cable and Bowden tube Install is accomplished by placing adapter plate onto differential side cover via two 13mm nuts Removal of the 901 eyelet will be necessary. This can be accomplished by cutting the old eyelet and plugging hole with automotive plug Failure to plug hole will yield hole in side cover Slide 35 Getting Started (Partial Disassembly) ![]() In order to attach the cable extender to the 901 or 914 Tob Fork, you need to attach the adapter piece which will serve as a guide for the knurled extension
Alex Olaverri Sales Associate for Bug@5-Speed (US) Email: Bugat5speed@yahoo.com Tele: 973 204-5463 Last edited by Bug@5speed(US); December 13th 2007 at 21:54. |
Slide 36 Bug@5-Speed Rear Gearbox Support
![]() ![]() This is the bell housing side of the gearbox. The rear gearbox support is attached to the bell housing via beetle transmission mounts. It is affixed to the two flat areas on the bell housing Slide 37 Bug@5-Speed Rear Gearbox Support (Cont) ![]() ![]() Both variety of transmission mounts can be used with the Bug@5-Speed Traverse To begin the installation process, you must mark where the attachment holes will need to be Slide 38 Bug@5-Speed Rear Gearbox Support (Cont) ![]() With the bell housing marked, use a punch and hammer, to mark the pilot holes for the drill bit Slide 39 Bug@5-Speed Rear Gearbox Support (Cont) ![]() ![]() With the 4-holes drilled into the bell housing, the next order of business is to utilize a grinder or dremmel with grinding bit to create a flush mounting surface for the transmission mounts Slide 40 Bug@5-Speed Rear Gearbox Support (Cont) ![]() The last order of business is to attach everything to the bell housing with the manufactured supplied bolts/nuts or grade-8 or better hardware
Bug@5-Speed Output Flange
Slide 41 Bug@5-Speed Output Flange Install
![]() ![]() ![]() When ordering its important to know if you have the early 901 sized flanges (Large) or 914 flanges (Small) due to the different sized hole in the flange. Bug@5-Speed Flanges are affixed to the differential with the removed washer and expansion bolt (It is recommended that you replace bolts with new ones Tighten to recommended manufacture specification
