Old November 2nd 2009, 15:36
Very cool vid's! Super acceleration, speed and sound
Just be carefull out there..
Old November 2nd 2009, 15:46
Rule09 Rule09 is offline
Thx Walter!
I'll be carefull!
Grtz
Old November 4th 2009, 05:21
Very nice! I like the style - something different and very tastefully done! Great job!!
Old November 4th 2009, 07:13
vdubzack's Avatar
vdubzack vdubzack is offline
DAAMMN!! I Like that sound. Next video show the speedo.
Old November 4th 2009, 09:52
Nice video. She sounds great, pulls hard. I know you are proud to have it on the road.
Old November 4th 2009, 14:00
It drives super! The car feels good on the road!
Good brakes good stering good suspension good sound!
Only it's addicted.. I want more hp!
I think i need 2.7
Next video, the speedp and rpm gauges..
Old November 7th 2009, 16:00
Humble's Avatar
Humble Humble is offline
It definitely sounds mean, looks like it has plenty of scoot too
Old November 12th 2009, 00:56
sved's Avatar
sved sved is offline
What kind of 911 shroud are yoiu running. And do you have any pics of the case after the milling of it. I'm doing a DIY 2056 intercooled turbo setup with a 911 fan setup not much info on this or parts. thank you Dave Svederus
buy the way car looks and sounds great
Old January 10th 2010, 16:39
Is going to be a 2.7
Made by Udo Becker
Old January 11th 2010, 05:01
Good Choice! Udo builds good engines.
I would stick to OEM 94mm cylinders,to be honest.You have no gain in HP or torque with the 96mm vs. 94mm.A friend of mine bored OEM cylinders to 96mm and they split at 1 bar,same happened to AA 96mm cylinders.It would be better to go with a longer stroke.A 74mm or 76mm DPR crank would work great and get you more power without sacrificing reliability. - Sorry for the hijack Rule09
Old January 11th 2010, 07:25
The cylinders would be 103mm, i don't witch brand it's gonna be..
And the crank is a scat 80mm
With 5.5 Pauter rods with chevy journals
Old January 11th 2010, 16:31
new lightweight pauter rods . 5,5 length chevy rod journals and 530 gramm weight
54 gramm lifters
80 mm scat crank with gene berg dowel pins at the flywheel
