Old January 2nd 2010, 15:15
Humble's Avatar
Humble Humble is offline
ugh, I remember doing that job and it was no fun. I cut off as much rubber as I could from the spring plates then used a wire wheel for the rest. It took a whil but got the job done.
Old January 2nd 2010, 15:34
dub_crazee's Avatar
thats absolutely hilarious - i did exactly the same today as im getting my stuff blasted and powder coated lol! new bearings and bushes throughout
ive been searching for the large 'doghnut' bushes for the spring plates but cant seem to find them - are the only replacements avaiable the poly bronze ones from the likes of elephant racing ?(
Old January 2nd 2010, 15:59
I got some from pelican parts for my speedster. I think Wally did it the right way for internal bushes, but like humble the wire wheel is MUCH faster for the outer ones...
Old January 2nd 2010, 16:03
dub_crazee's Avatar
pelican parts was the first place i checked - maybe i was being blind! il check again.
i burnt the bushes off but i still need to get the remaining bits off - good idea with the wire wheel
Old January 2nd 2010, 16:32
You can get pure urethane for most of it, but I read up on rubber, urethane, delrin, monoball and polybronze in the 944 world. Very interesting and hence my choices for replacements. Only inner busings from 944 don't fit the IRS beam, but other than that, most 944 stuff applies. Noise, quality, costs, pick your poison
Old January 3rd 2010, 06:41
These ones?
http://www.pelicanparts.com/cgi-bin/...78%20-%2095%29
Old January 3rd 2010, 07:21
dub_crazee's Avatar
now i feel like a right fool haha i clicked on suspension bushings but not the next page - thanks mate
Old January 4th 2010, 15:43
kuleinc's Avatar
kuleinc kuleinc is offline
I was looking forward to replacing all the rubber in the rear suspension, I take it the diagonal torsion bar thingy rubber replacement is a PITA then?
Everyone told me its not a good idea to daily drive an aircooled bug. I agree, if the engine has a distributor and you use cheap engine parts... OR you have an early car without the decklid vents or you neglect to add an oil cooler with fan...
Old January 13th 2010, 14:57
In the meantime, the Heigo rollcage came in and I test fitted it today:
It really fits nice and is very close (good) to roof and the A- and B-pillars.
Old January 13th 2010, 15:47
OK, I REALLY like that fit, do a have a shot of the distance to the roof? Is there a US distributor for HEIGO?
Old January 13th 2010, 16:04
Yeah, here it is, but dificult to see because of the very contrasting white headliner and flash...In reality its snug against the headliner. I had to specify steel sunroof or not. Its that critical. Piece of german 'kwalität'
Old January 13th 2010, 16:50
That cage looks fantastic Walter, superb fit.
Check out http://www.fvd.us
I think I found a Canadian distrubutor as well
Old January 13th 2010, 17:19
The weight wasn't too bad either: the package was heavy as fock but the certificate showed it was 'just' 35kg's while I expected like 50 or 60 kg.
I think I'll just add one bar behind my head to mount the drivers side harness onto.
Old January 13th 2010, 18:26
Jim's Avatar
Jim Jim is offline
This is very nice and safe addition in your car wally, it will be more stiffer now in the corners!
... and as i see from the photos it needs a little triming in the dash in order to fits nicely!
Rgrds,
Jim
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old January 13th 2010, 22:36
That is one sweet cage Wally. Very, Very nice!
