#796
Actually, koni does make uniball equipped shocks but they are double adjustable racing spec
The 2800 series are the cheap end and pretty damn nice but I don't know what they cost off hand (probably not cheap).Hopefully the m030 shocks work well for you, when I tried them on my lightened car I found they were too stiff. |
#797
Hey Wally,
finally got to see your car up close in the flesh - love it. only saw your first run though! crackin car - it's been an inspiration for me building my own! Shame i didnt get to meet you Deano |
#798
Wally ran a 11.48 his PB fastest car in DKR at the moment
cheers andy |
#799
11.48 from a turbo typ4 with 911 cooling a true myth buster.
#800
Yes, pity indeed. There was plenty of time on sunday, but a very large compound and a lot of people there as well ![]() ![]() Tnx for the kudos! It was fun and thats what its all about. |
#801
11.48 in the fat chick and a long G50 gearbox!! That´s awesome! Gefeliciteerd Wally! (hope I spelled it right
#802
Maybe at bugjam or Action if you are going?
Did you get any vids of your runs? |
#803
I did video the one run alone in the car on saturday that should have been thé one, but the higher boost caused spark blow-out as far as I could tell from the log, so I rather not post it ![]() Birdman did tape up his video camera in the car for our passenger run but it may take a while before he can put that online as he's not back in aussie land for a week or so iirc. |
#804
was good to catch up with you over the weekend and well done on the PB.
#805
Thanks m8. Good to talk to you again, even if it was only briefly.
#806
This is what happens if you run into the 'hard-cut' rev limiter:
![]() Some of you may recognise this phenomenon from my previous encounter with the hard-cut; yes, this already happenend before... ![]() This time I wanted to test flat-foot-shifting, so soft-cut was lowered a lot and hard-cut set at the same rpm distance from the soft-cut, about 600 rpm. This will never happen again now, as I will now set the hard-cut 2000 rpm or more away from the soft-cut. The cure is apperently worse then the problem it tries to prevent... |
#807
Ouch.
I hope that rocker was the only component damaged, and nothing else was hurt. Was this the same exhaust rocker (same valve) where the break happened previously ? Sandeep |
#808
Wally maybe the Pauter ones might be the solution.
VW 1303s 1975 (German Look) VW 1300 1964 (Rally Car) LAND ROVER DEFENDER 90 V8 BMW E30 318i CONVERTIBLE 1992 Italian Toys - GERMAN WAR MACHINES ![]() WRC is for boys - GROUP B WAS FOR MEN |
#810
Damn, again? What kind of pushrods are you running and how long were you on the hardcut? I've spent a few seconds on the hard cut (500 rpm between soft @7500 and hard @8000) on longer straights so I'll have to watch that
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
