#1156
I knew if I wrote enough, there must be something that makes sense now and then
![]() Cheers guys ![]() Anyways, I finally remembered a little thing that was almost forgotten: maching the flywheel for the central pinion bearing... ![]() Got that done today, so finally the flywheel and clutch are on the engine. ![]() Also bought a set of new CV's for the outer sides only as these Lobro/GKN ones are quality but 4x as expensive as chinese Empi ones (assuming those are the cheap ones). Hopefully I can finally put the engine in later this week and finish the install over the weekend. |
#1157
Are you using regular 930, or the big boy 934/935?
The time I bought Lobro 930s they were $55 per joint. That was a few years ago... Steve
Steve Arndt |
#1158
All I know are the 108mm outside diameter "930" Porsche CV's, which is the size some/most 915 transmissions already have and is also standard size for all G50's. However...I have converted to Richards/Steve's idea and fitted the 100mm flanges from the front 964 diffs and still used my beloved T2/T25 100mm VW CV's and axles. So, these Lobro's were over 110 euro's each, even with my discount at the parts store... Thats why I only bought two, not four ![]() Just swapping out the outers now before engine goes in, so much more easy. |
#1159
![]() 934 CV on left - 930 CV on right. 930 are big compare to T2. 934 are HUGE. http://www.duneguide.com/sand_dune_tech_cv101.htm
Steve Arndt |
#1160
Pity it doesn;t show dimensions of the CV outer diameters, but the read on assembling was good. I learned something new anyways, thanks!
#1161
Here is a link the the GKN catalog. http://www.rowland2.com/pdfs/cvdisc.pdf
I believe 930's are size 15 CV's and 934 are size 21. They have both plunging and fixed in this catalog. -Dave
#1162
930 is then type 15 with 108mm 934 would be type 21 and is 128mm (!) The weight difference: T2 : 1,4 kg 930: 1,8 kg 934: 3 kg (!!) If I can keep the T2 CV's in one piece (and assuming we use type 174 in that catalog), that alone saves me almost 0,5 kg unsprung weight per wheel and almost 2kg total weight for the 4 of them. Not to mention what you would drag along with 934 CV's... These things add up fast. Last edited by Wally; June 8th 2012 at 02:23. |
#1163
I missed the details Wally. How are you running 930 and T2 on the same axle? The splines are different. I inquired years ago to Sway A Way if they would build me a set like that and they said no way.
Steve Arndt |
#1164
The axles and CV's are still exactly the same as I ran them on the 915
#1165
Engine finally in after I was able to lend a 930/G50 shaft to align the dual plates..
FYI, type 1, 915 and 930/G50 splines next to each other...Guess which is strongest ![]() ![]()
#1166
Hi Wally,
You know what, I wish I had gone for the G50 box way back when the chassis was being done. We will wait and see. It is a hell of a lot of work to get everything out if I break something. I have got some real tasty pictures from John Maher of my engine but can't get them to upload onto the site. Any ideas? |
#1167
I hear you mate..
Curieus to your engine! Just mail the pics to me and I'll upload then for you. I'll send you a PM with my email. Greets, Walter PS I just installed the last bits of my rebuild engine. Hope to start it tomorrow evening and have it running this weekend. I'll try to take some pics tomorrow as well. |
#1168
Wally, your G50 is the smallest of the G50´s correct? As far as outside dimensions.Which one is it exactly? Hope you get back on the road this weekend!
#1169
Mine is a G50/01 ('88). The G50/00 ('87) also have the short nose cone. After that ('90 ->), the longer nose cones came into production. As you may remember, I also had the bellhousing shortenend. Every little bit helps ![]()
#1170
Thanks for the info! Looking good! A new bov also? Can't wait for the next track video!
I'll see you in Spa! |
