Old March 27th 2015, 08:54
effvee effvee is offline
Walter, inside the head, the intake; what do you use to produce that texture? I understand it's for air fuel atomization. Every time I tried to ruff up the intakes, I could never get that result
Old March 28th 2015, 12:19
The best surface after porting is to sandblast the port.
Old April 25th 2015, 11:18
Only just saw your post...
For the record: I did not port or machine or do anything to these heads. All work was done by Jakob Spring from Danmark. I mentioned his website before iirc.
My best guess however is that he used a rolled sandpaper bit in a drill or dremel to finalize smoothing of the port, which also gave it that structure.
Old May 31st 2015, 09:40
Finally found one (1, so it was cheap) front left caliper and was sooo curieus if it would fit the 350mm disks...
It did!
Old July 17th 2016, 03:54
I see I need to update a bit here
Finally got the cylinders machined to fit the heads. I kept wall thickness as big as possible and ended up with almost 9mm wall in the 98mm bore!
First trial fit with heads and cylinders test-assembled:
Old July 17th 2016, 10:14
Looks fantastic!
Old July 18th 2016, 05:13
Wow,it look fast.
Old July 19th 2016, 13:49
cookvw's Avatar
cookvw cookvw is offline
looking awesome as always wally!
Old July 29th 2016, 21:45
chug_A_bug's Avatar
Very nice.. can't wait to see it all built..
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old August 13th 2016, 12:58
The (Pauter) rods and straight cam timing gear are ordered, so I should have all parts for the long block in a month or so
Old August 13th 2016, 13:17
Wow, didn't know, they allowed porn on this site . Very nicely done.
Old August 13th 2016, 14:23
Bad bug's Avatar
Bad bug Bad bug is offline
It did!
Walter is that a carbon disk rotor you have there, may i ask which hat are you using with the disk.
Old August 13th 2016, 14:26
Bad bug's Avatar
Walter is this a ortech shroud.
Old August 13th 2016, 16:06
Yes, its an Orratech system. It wasn;t designed for type 1 exhaust port heads though, but thats easy.
The disk hat is original Porsche, but off-set is a few mm short.., so it doesn't work/fit at the moment and I need to adress that issue as well before I can drive again.
The off-set problem is not as simple as it sounds to be though.
On the positive side, I did find the other caliper!
Old August 17th 2016, 10:05
cookvw's Avatar
looking awesome wally. cant wait to see this motor running and see what it will put out for power.
Currently Active Users Viewing This Thread: 17 (0 members and 17 guests)
