#1501
Had a great track day for the first time after 6 years together with a good friend of mine in the grey german style 1303 with 2 ltr T4 and some Porsche friend of him.
#1502
Zandvoort!!
thumbs up; thumbs up; (smilies did'nt work!!)
---------------------------------------------------------- Greetings Gerold ![]() STi powered Typ4 in the works... R.I.P. 1302/'72 Last edited by 412STi; July 20th 2018 at 16:54. |
#1503
You live my desired life, Wally!
johnL (aka H2OSB) '74 1303, Outlaw sedan (with a GL flavor) |
#1504
Haha! I'am sure it isn't that desired
but thanks for the nice reaction ![]() I did find an issue with the limitations (lets hope its just that) of the breathing capacity of the engine as on contineus high revs plus boost, too much oil fumes came out of the breather box. Just added the little can under the oil plate so sump is a little bit deeper, so the dry sump can do its job better. Also ordering a larger breather box. Hopefully both these will keep it under control. |
#1505
#1506
Nice video, my wife would probably freak out on track going that fast!
#1507
Nice video, your gearbox sounds like mine
#1508
haha, I WISH mine sounded that good :P Everyone who rides in my car asks if it's about to explode.
#1509
![]() We run the same gearbox obviously hey Steve ![]() It is indeed pretty loud on lift-off. Since its still in one piece after all these years and abuse, I'll leave it be
#1510
Love my G50 it still works after all hell I give it
#1511
That sounds delicious!
H2OSB
#1512
Well, not everything works out with my builds too as these pics prove:
![]() Torched a cylinder and head big time! Root cause probably the one-off cast cylinders. No matter how thick the walls were... Partly also my own fault as I didn't retorque the heads more often, which would have been more wise because the cast cylinders did need more 'seating' then I usually am customed to. I noticed this when disassembling the engine: head torque was too little on the other cylinders, so thats probably what started this. Still, all other cylinders also showed a much larger bore up top then bottom of the cylinder (!), so they just didn;t stood up to the cylinder pressures I ran anyways. That also explained the excessive breathing I experienced: the rings just couldn't keep it sealed up top in the cylinders.. Anyways, for a 'quick' fix I bought a set of the AA 98mm birals so I could reuse at least my pistons. Head is fixed at the moment already and I am reassembling the engine again
#1513
Walter, what happen to your Ottinger Cylinder?
#1514
Walter, what happen to your Ottinger Cylinder? The width of the sealing surface looked thick enough.
#1515
| Currently Active Users Viewing This Thread: 14 (0 members and 14 guests) | |
