#19
When I'm done with testing carburators and no longer need the AEM gauge and o2 sensor in the exhaust I will replace the CSP Python with the GPP exhaust.
Before I could install that exhaust I had to do some tedious but important mods. First I matched the inside opening of the copper gasket rings to the exhaust pipe. ![]() Now all 4 gaskets have the same size as the exhaust pipe mating surface ![]() On one of the exhaust pipes the mating surface was not completly flat. On the picture below you can see it almost done, there is still some black marker visible. ![]() And on one side the pipes were not perfectly parallel to each other so I spend half an hour doing this. Just like Jeff often said on homebuild by Jeff on youtube https://www.youtube.com/watch?v=jfPmTOin29w MORE SANDING.. YAY!!. ![]() I did a leak test with an aircompressor and some soapy water and it's leak free. |
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
