Old September 30th 2010, 18:23
B-rock's Avatar
B-rock B-rock is offline
Vented Front Fenders
Does anyone know where to find front fenders with boxed vents in the rear like the these? My guess is that they are custom made but maybe there is a supplier somewhere?
File Type: jpg phoca_thumb_l_phoca_thumb_l_IMG_1038.jpg (79.9 KB, 120 views)
Old September 30th 2010, 19:32
The first two shots are a Remelle car, and most likely one-offs, and even if they did sell them, Remelle stuff is notoriously hard to get a hold of.
Then second shot the hole is just cut into the fender I believe. Order up a set of fiberglass fenders from CCC and cut out whatever you like. I've also seen large holes drilled with say a 3" hole saw in the same area to allow the trapped air to escape.
Old October 1st 2010, 19:42
B-rock's Avatar
The white car has the boxed fenders too. I just didn't have a good picture of that car. Here's a video of it in action:
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/4Yv9kbs_V-M?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/4Yv9kbs_V-M?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Thanks for your input Volksdent! I may resort to drilling holes in CCC fenders.
Old October 1st 2010, 19:49
B-rock's Avatar
Opppps......Here's a link to the video.
http://www.youtube.com/watch?v=4Yv9k...ext=1&index=25
Old October 1st 2010, 20:37
Very cool video!!! Those fenders are still different though than the Remelle, again probably one offs. Remelles have a box extension, the white bug looks to just have the area removed and edged.
Old October 9th 2010, 06:38
Best put some wire mesh where the hole is if not tour rear fender will be visiting the paint shop often! Or you a deflector plate under the fender.
T4 2666 1303s
Old October 15th 2010, 12:08
Yes,the blue car is an old Remmele car and the Fenders are carbon fiber custom made for this car.
Old October 19th 2010, 23:05
B-rock's Avatar
Yikes! I guess I better learn how to lay down some carbon fiber!
