Old November 9th 2011, 10:17
aircured's Avatar
aircured aircured is offline
Locked Out
unable to open the bonnet, seems like the pull-cord catch has dropped.
does anyone know how to gain access without damaging the bonnet.
cheers
'72 Type 1 - GT
'69 Type 2 - Bay
Old November 9th 2011, 13:40
owdlvr's Avatar
owdlvr owdlvr is offline
http://www.midsouthvw.com/TechTips/t...eningTrunk.htm
Scroll down to the bottom. Last option is your solution.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old November 9th 2011, 20:20
aircured's Avatar
cheers Dave.
will give that a go.
'72 Type 1 - GT
'69 Type 2 - Bay
Old November 10th 2011, 08:51
Not as scary as it seems.
I would recommend using a large bung for the rear of the spare wheel well and rigging up a piece of wire for in case of future failure
Old November 11th 2011, 03:15
If you move the lever towards the side it will go past its normal stop rest.
This is what you need to do with lever to get just a bit more travel that can sometimes pull the cable enough open the bonnet. You pull the lever over so that it can go past its normal stop.
Other than that you can cut the bonnet handle to release the lock.
I always fit a secondary cable release under the mudguard.
PS I had trouble loading this photo, let me know if you cant see it
Old November 11th 2011, 07:05
aircured's Avatar
thanx 4 the info
ps unable to see the photo
'72 Type 1 - GT
'69 Type 2 - Bay
Old November 11th 2011, 09:19
Originally Posted by aircured View Post
thanx 4 the info
I cant understand what's happening, I cant load this photo, its only 72 kb. I will try to send it in a PM
