Old March 2nd 2004, 16:27
judgie's Avatar
judgie judgie is offline
hopefully new engine spec
hello everone
this is the spec of my new motor have i missed anything?
heads
44x38 trw valves
46cc chambers
lightenend rockers
welded intake poets
911 exhsorst port stubs
10.5 cr
case.
5th studed head bolts
1/2" case bolts
dry sumped[3 stage]
lightenend and balancd crank and rods[arp bolts]
web 86c cam
ceramic lifters
berg cro-mo pushrods
magnum stright cut steel cam gears
steel 200mm flywheel
trw forged 94mm pistons with dyks rings
carbs are going to be 48 idf's[38mm chokes]
not sure on ignition yet
cheers rob
