Old November 8th 2004, 11:02
4SPEED's Avatar
4SPEED 4SPEED is offline
Question 6 pistons
Hi,
I seek a supplier of calipers porsche GT3RS (6 pistons red)
thanks in advance
Old November 8th 2004, 17:39
justdubbin's Avatar
Here are two sets that I found on ebay, check them out
First one
and the second
Good luck.
What wheels are you planning on using ?
Rob.
Old November 9th 2004, 03:09
4SPEED's Avatar
wheels "RH in 18' "
thanks for your reply
Old November 24th 2004, 09:43
Looks BAD A$$ :agree: Well done
I hope you are using a fairly wide front tire to complement those brakes.
Old November 24th 2004, 12:19
bigwindow bigwindow is offline
Looks damn good!!
What size do you have on the discs?
What kind of spindles are you running?
1963 Germanlooker projekt
1969 T-1 daily driver
Old November 24th 2004, 12:37
Racelook's Avatar
Racelook Racelook is offline
Looks nice...
B-Extreme B-Tuning.....
Old November 24th 2004, 13:33
Ghia discs= good brakes
944 sliders= outstanding brakes
4 pot Brembos= overkill
6 pot Brembos= Ludicrus?...me likes
Old November 24th 2004, 21:23
WOW!!!!!
those look awesome. hope you have good seatbelts or like the taste of glass.
permission to add pics to the gallery?
Old November 24th 2004, 22:28
Mikey's Avatar
Mikey Mikey is offline
I agree!
Mike
'04 R32 Tornado Red
Old November 24th 2004, 23:44
Holy... sweet mother of.... Nice brakes...
Old November 25th 2004, 00:13
Holy yellow banana of all brakes!
T4 2666 1303s
Old November 25th 2004, 05:13
Typ Vier Typ Vier is offline
Hi,
I`m using disc brake spindles of a 72 ball joint axle, took 2 CSP discs (SEBRO) with Porsche 5 stud pattern and machined them down to the inside diameter
of the GT3 discs and use them as hubs. Then machined the back of the discs(hubs) to fit Porsche press in wheel studs. It is pretty much a bolt on kit, the discs (GT3) have plenty of clearance. After that was just measuring up for the caliper brackets and getting them made. On the rear is the same stuff as most of you are already using, 944 hubs and backing plates, modified handbrake adjusters (thanks for the tip Sandeep) and new BMW brake shoes. My goal was to fit this brake with 17 in wheels even though they fit 19`s to the Porsches. It is very tight and there are only 2 mm clearance between the caliper and the rim, had to take the balance weights away there.
The wheels were another problem as I already had a set of Boxter style 996 wheels (twisties) which did not spin as the caliper was sticking out of the hole. Would have needed a 30 mm spacer to clear it. The ones on it clear it nicely with a 10 mm spacer and don`t look to bad, so they stay.
Discs are 330 mm on the rear and 350 up front, gonna try 944 master cylinder and brake proportioning valve for the rear. There will be a lot of testing. The tyres are 205/40 in the front to keep the original look, so testing different components to ensure driveability is necessary.
Andreas
Old November 25th 2004, 05:17
No worries, if you want to add the pics to the gallery go ahead Zen.
Cheers
Andreas
Old November 25th 2004, 11:12
WARNING the following your about to read is a bad joke, disregard:
Is that a banana in your pocket, or are you caliper to see me?
Old November 25th 2004, 19:33
Oh that is bad...
