Old December 20th 2004, 16:20
Scotts73SB's Avatar
Type 1 DTM shroud... what lower tin?
Hey Peeps! I got a question. I am currently running a type 1 DTM shroud and the lower tins i have on there are the flat square things with 2 tangs sticking up on each side that go between the 2 cylinders.
My question is.. I was reading on another forum and they said to use the whole cylinder shroud piece as seen here..
http://www2.cip1.com/ProductDetails....C%2DC10%2D5444
So.. should i ditch the little square dealies with the tangs and go with the whole shroud piece? I read that Jake R said that to make efficient cooling you need to make pressure.. so im wondering if i need both tins on there?
Thanks a million.
Scott
Old December 20th 2004, 17:47
I am running a T1 DTM on a 2275cc. I was one of the test monkeys. I do not run lower tin on mie. I do have the defuser tin(stock snap in)above the push rod tubes. I have had no trouble with cooling the heads/cylinders.
Old December 20th 2004, 19:44
onixbonilla's Avatar
onixbonilla onixbonilla is offline
By a newsletter released by VW back then, those cool tins were designed only for the type 3 cooling systems and should not be use on type 1 cooling system(similar to DTM), states will run hotter.Personally I do not have a copy of that newsletter, but neither had any problem with the orignal type 1 ones.
Onix
Old December 20th 2004, 23:46
Scotts73SB's Avatar
Ohhhh awesome!!!! Saves me some work!!
my engines a tad smaller than yours NoH20 so i should have no prob
Thanks for the replies!
Old December 21st 2004, 09:26
you can always call jake and ask. or post on his forum. he is good about responding...although he is slammed at the moment. one note on no_h2o's engine. it has big jugs, so that may automatically provide some back pressure without the tins as compared to stock or smaller jugs.
Old December 21st 2004, 11:50
Massive Type IV's Avatar
The Type I DTM was developed with the stock Type I tins. It was designed to work with the backpressure and resistance created by these tins only.
Avoid all other tins- Period.
Jake Raby
Old December 21st 2004, 18:56
Scotts73SB's Avatar
Cant argue with the master!
Thanks!!!
:bowdown:
Old December 21st 2004, 23:29
Scott, did you get my email..
Jake Raby
Old December 21st 2004, 23:45
Scotts73SB's Avatar
Nope didnt get it..
Ill PM you with both emails just in case.
doh!! you pm box is full. I shouldda known that.
Email is in the profile.. maybe its just slow.
