Old October 14th 2005, 14:26
Type 4 cooling
I know there has been spirited discussions on the merits of the 911 fan versus DTM for the Type 4 engine.
Does anyone have any experience with the horizontal fan?
I have read Tuna's Web site. I'm just mulling over options which would still allow a 1302 to retain its decklid.
Old October 14th 2005, 14:49
The FAT 911 setup requires a small half moon cut in the decklid, and you need to drill 2 small holes to move your licence plate light up about 3/4".
This places the light right above the moon cut and hides the cut very well ... use a dremel with a cut off wheel and you will not damage the paint when you make the cut.
This 911 setup requires the factory 911 alternator cap with built in diverters and a small sheet metal plate on top of the 3-4 bank, as well as T1 under cylinder tins ... search for "911 fan AND datalogger"
Or you can use a DTM ... the choice is yours.
Old March 17th 2010, 15:59
redhot redhot is offline
So - horizontal cooling.
Riechert (only used available?)
LA. Performance
What is there to this cooling system in reagards to pros/cons?
Pro - no need to machine case is the first I`ve found.
Other experiences?
