				Help !!!!!
			i remolded my dash and when i took it out i forgot to mark the spedo wires. i got the top of it but i cant get the oil, alt, and turn indicator to work. can anyone help
	  . It is a 1975 Super thanks
			Try this link for a color wiring digram.
			http://vintagebus.com/wiring/ the Oil Press, Atl, and turn ind. require power to the speedo with one wire then each ind. light get a ground from their respective sender or the flasher.
	NO_H2O 72 1302 Smack Black GL 73 Bus (2L CIS Powered) 66 Beetle, 73 Standard Beetle 72 Pinzgauer 710M Volksport Kafer Gruppe  |
			The guy that runs that website is from Sacramento.  He has a really nice bus, but he also has two bad @$$ 911's.  One of the 11's is setup for racing.  I used to work across the street from him, well I was heading home.  Not doing anything crazy just cruising when all of a sudden i heard the pitch of the engine change.  I let off on the gas then goosed it, all hell broke loose.  Pulled over, opened the deck lid.  Aluminum was everywhere, and a valve stem was sticking out of a intake manifold on my 1641.  I very nicely done Super pulled over to see if I needed any help, and a mean 911(vintagebus.com guy) pulled over, he was rocking a VW hat.  Moral of the story, if your gunna run 044 heads throw away the made in china SS valves and put in some Manley's.
	PS sorry about jacking the thread  |
			Thanks for your help but i actually figured it out shortly after i posted this thread. i guess i was just making it more complicated than it needed to be
