Old July 12th 2006, 21:48
Bullyboy Bullyboy is offline
Sexy bars
Just got my 3 bar set-up from Lanner yesterday.
I just happened to be powder coating stuff in the garage and they ended up looking like this
Very nice quality stuff:agree:
More powder coating stuff in my album
http://www.imagestation.com/album/pi...?id=2105477818
Old July 12th 2006, 23:35
Mikey's Avatar
Mikey Mikey is offline
Nice colour. I got a set from lanner too. Top notch quality. They look awesome. A shame it'll be under the car.
Mike
'04 R32 Tornado Red
Old August 1st 2006, 23:59
Got my bars fitted up, mounts welded, and powder coated.
Old August 2nd 2006, 00:02
Old August 2nd 2006, 07:18
flat flat is offline
Mr. Bully,
Looks amazing. I should be anodizing those things.....
Good work. Are the brakes on?
www.vdubengineering.com
Old August 2nd 2006, 07:43
Tim Tim is offline
Hi Bullyboy, nice setup.
I noticed the KYB shocks mounted on the 944 alu arms. Did you enlarge the bushings of the shocks and used 14mm bolts?
Tim
Old August 2nd 2006, 08:45
Hey Lanner
I just PC'ed the spindles last night with the rest of the blue stuff so I am still working on that end of things.
Tim
I drilled out the shock bushing for the stock 14mm bolt.
Later Mark
Old August 7th 2006, 17:14
iamstumper's Avatar
iamstumper iamstumper is offline
Those look amazing! I'm looking at a set of bars myself, and these had me stop.
Since seeing these, I've looked up both the powder coating and annodizing "kits". The results definitely speak for themselves ... at least to me!
Lanner:
Does " .... should be annodizing ...." translate to will be in the future? Or just tossing it about in the ole noggin'?
- Stumper
the Beast - '73 SB Sedan
Fraulein - '79 SB Vert
Old August 7th 2006, 18:17
nice indeed. Lanner, i would like to drop a pic in the gallery. i will use one of these inless you have a different one you want to donate.
Tim
Lanner (flat) also makes replacement bushings. that is what i did on mine. my Koni's did seem like they would have enough meat left on the bushing for my comfort.
Old August 10th 2006, 15:09
iamstumper: Anything is possible if the pockets are deep enough. Anodizing will cost about $C50 set (3 bar). If guys want to pay the premium, I'll do it.
Zen: I don't have any better pics, I suggest you grab the ones in this post.
Old September 4th 2006, 21:18
Pulled the body off the other day to do some more work on the pan
Got my brakes back together just need to figure out the pads???
more pics at
http://www.imagestation.com/album/pi...?id=2109248753
Old September 4th 2006, 21:25
Nice color on the calipers. Lots of detail all over that chassis too!
Old September 6th 2006, 18:57
chug_A_bug's Avatar
love the colours and the detail that you have spent on it nice job
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old September 6th 2006, 20:50
Bad bug's Avatar
Bad bug Bad bug is offline
Bully boy the gearbox support piece in blue where did you get that to buy, does vdub engineering sell them.
Old September 6th 2006, 23:50
Just the standard one from CIP
C13-9543 - ULTIMATE QUIET HEAVY DUTY TRANSMISSION REAR BELL HOUSING STRAP ONLY - BEETLE 61-79
The color is ford dark blue. I keep telling myself to stop making it so clean or I'll be scared to drive it.
