Old June 15th 2007, 18:08
Chris Percival's Avatar
Brake disc 'runout' specs
Anyone know or can point me towards runout specs for Porsche discs?
Old June 16th 2007, 11:26
Eliasson Eliasson is offline
What kind of brakes do you have? I will se if I could find sometings about it.
Old June 16th 2007, 11:59
They are actually 95-98 Porsche 993 rear discs mounted on modified 944 hubs (to fit beetle bearings). Too be honest it could be the runout spec of any large disc. I need to check them when mounted on the modified hubs..
Old June 16th 2007, 13:26
JIMP JIMP is offline
Hello
if I'm not mistaking too bad, I think acceptable runout it's something like 0,10 to 0,15mm, more than that I think it will cause much vibration on the steering wheel on braking, especially on fixed calipers (not sliding) like the rear that you mention
Friendly
JIMP
Old June 17th 2007, 06:57
Here I found something for your 993 discbrakes
Brakediscs minimum after machining
dimension wear limit
front 30,6mm 30,0mm
rear 22,6mm 22,0mm
Thickness tolerans of brakedisc
0,02mm (new 0,01mm)
Lateral runout of brakedisc max 0,05mm
Lateral runout of wheelhub max 0,04mm
Lateral runout of brakedisc when installed max 0,09mm
Old June 17th 2007, 16:13
Ah thats wonderful, thanks guys...
Old June 28th 2007, 11:01
Sunroof53's Avatar
Sunroof53 Sunroof53 is offline
0.05mm or .002" .Any more and you may have problems.
The wisest mind has something yet to learn
