Old December 1st 2008, 03:56
hurley209 hurley209 is offline
tailight help please
i recently put on some flat low profile tail lights on my beetle, but the right side is not as bright as the left side, and also i cant get the blinker signals to work. i know its a different wiring set up. Do any of you know how to make these work like normal?
Old December 1st 2008, 09:42
Have you checked that the lights are properly and effectively earthed. The dull lighting level is symtomatic of high resistance in the circuit that I assume worked before you swapped the lights over.
evilC
Old December 1st 2008, 12:27
nope, it was dim ever since i got the car, just never really payd attn to it.
Old December 1st 2008, 23:25
yellrhd's Avatar
yellrhd yellrhd is offline
Good chance you have a bad ground on one side.
You also should check to be sure your sockets for the dual filliment (1157) tail and stop light is correct you may have them reversed.
Many of the aftermarket kits have som pretty poor set ups for the sockets and many have the locator tabs backwards which can be corrected by just switching the stop/tail wires.
An Air Cooled in the land of Rice Burners
