Old December 26th 2009, 17:55
Originally Posted by dub_crazee View Post
Wally are those 2.7 boxster calipers or boxster S calipers you're running on the rear? What front discs are you using?
Hi (Rob, was it?),
Those are 986 (2.5 or some early 2.7) front calipers. No Boxster S as Boxster S (987) are actually the same as 996 and have 28mm thick front rotors! I have 24mm rotors in the rear, same as front 986. See?
On the front of my bug I now have 330x28mm and I use 996 front calipers for that. Originally 996 fronts are 318x28, but those calipers work very well on 330 too
Progress: adapters made:
Old December 26th 2009, 19:32
dub_crazee's Avatar
Hi (Rob, was it?),
Ah okay, 944T and 987 rear discs are also 24mm thick arent they? (but i beleive the 987 discs are slightly taller)
i am going to be running the 318x28 discs on the front. Did you find much of a difference going over to the 944 mastercylinder from the beetle mastercylinder?
its great learning from others' experiences on here, especially when the cars get used on the track
Deano
ps did you ever run rear 996 calipers?
Old December 27th 2009, 06:04
Sorry Deano
Yes, they are, most all rear disks are 24mm I noticed; The hats are indeed taller/shallower with each model, so you need to check out what will work for you.
Yes, 23mm or 19mm in the front will make a big difference. But even with the 944 master and mounting the lines so that 23mm is to the front brakes (thus lessening the brake power on the front), on MY car, the rear still didn't bite enough. Or in other words: I still leave braking power on the pavement, it can be better if my rears work harder.
Most all rear porsche 4-pot calipers (including the 996 ones) have something like 28/30mm cups in them. For MY car with 245 wide semi-slick tires, that is just too little I found. Even the 993 rears I had had the largest rear cups I could find (30/34) and even that was too small on MY car.
Notice I said MY car, as I am sure others will have different experiences with their cars wih different set-ups
I just hope to have solved the bias with the 36/40 cups in the 986 front calipers...I'll et you know how it turns out next (track-day) season
Old December 27th 2009, 13:22
effvee effvee is offline
Very nice work Walter. Question, presently I have the 1985 944 rears for both front and rear. Do you feel fix caliper do a better job than floating calipers?
The reason for my question is due to, on my Chevy truck I have floating calipers and the right front wear every time faster and sticks. This is due in large part to the floating caliper design. However, over here fix calipers are hard to find. Unless I want to go to the Porsche junk yard and get rapped by sticker shock
This is the front caliper on the rear, I feel I can't just use four wheel disk brakes from a 944/front engine, and not try and even out the braking. I have a old, I believe a 1970 911 book, in it, they use pretty much the same diameter calipers on front and rear. Leaving the larger caliper on the front, I feel would cause lock up too easy.
