Old October 3rd 2010, 15:35
kai4130 kai4130 is offline
Originally Posted by Luismj View Post
I have the some problem but wth GTI engine and similar type 1 trans.
I am very interested in the solution that you find!
Do you use extended arm on trans?
If your running a type one box in a type one then you should be able to get away with using the Saco kit as it's intended for a beetle and will "bolt on"
Are you using a Kennedy clutch? I was told by a local conversion garage that the Kennedy clutch (for my Porsche to Subaru) is a very stiff set up, possibly a little over kill but this is not helping my super still pedal.
