#631
Impressive, as always! How will you route the oil return line, with the turbo that low?
#632
Welcome to the board Frix!
Oil return will run as it was before with the former turbo as its about as high or low as the other one was
#633
Looks great Walter !
Well thought out, and looks like the turbo was meant to fit there. ![]() Did you end up revising the down strut / cup brace ? Sandeep |
#634
Oh well, first have to finanlize the install completely with WG before I do anything drastic. I also wanted to redo the piece of 2" pipe just after the intercooler (2,5" exit) and the T-split. The individual 2" pieces to the pressure hats can easily remain 2" imo, but making the intermediate bend from 2,5" just seems more logical:
#635
Steve Arndt |
#636
You're reading ricer forums now? ![]() j/k its a good thing to broadthen (sp?) our minds and apply new (although usually very old) tech to our engines/cars ;-) Last edited by Wally; January 7th 2011 at 15:43. |
#637
You too!
#638
I agree!
![]() Walter, what's with Your 1200 turbo engine and will you have thread here on GL forums about build? That downsizing stuff is very popular now
1967 Bug |
#640
. Its slow progress too as it all costs still a lot, even if its type 1.Meanwhile, some progress on installing/trial fitting the Tial wastegate, trying to outsmart the system by just using one WG by dividing the uppipe ![]() Divided pipe is now visible, of course needs to be shortenend and connected to both up pipes to turbine. ![]() ![]() New wider pipe to the intercooler fits well too now, almost straight shot from the turbo ![]()
#641
Looks like it´s getting tight in there now
I suppose there´s no way of locating the WG further upstream?
#642
Just for the WG there would be room upstream just under the rear valence right after the 4-2 sections, but I saw no routing of the neccesary slicencer anymore then.
#643
Getting close. I look forward to some new videos.
#644
Yeah, coming saturday I hope to get the oil return outlet for the turbo and have the flange machined flat again as it has warped a bit after my welding...
Still the main downpipe silencer is not here yet and that needs lots of modifying too. Lots of work still. Last edited by Wally; January 13th 2011 at 17:12. |
#645
Flange machined flat again after it warped after welding and the neat oil return flange:
| Currently Active Users Viewing This Thread: 8 (0 members and 8 guests) | |
